Could you please add a “Humidity” under the custom widgets category? Unit would be percent %.
Thank you.
Rick
Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
This option is still available. It doesn’t have to be tied to a Value widget, but as an example, you can see it by going to Add New > Device/Widget > Custom Widgets > Value – here you’ll be able to choose Humidity as a data type and % as a Unit type:
