HELP ME esp8266 and read analog
hello what read info fron analog 0 in cayenne …no detect pin a0
//#define CAYENNE_DEBUG
char ssid = “Hostal las Ventas”;
char wifiPassword = “xxxxx”;
char username =
char password = "
char clientID = "
unsigned long lastMillis = 0;
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(A0, millis());
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
which esp8266 device you are using? you need to start this if using a wemos D1_mini_Examples/ReadAnalogVoltage.ino at master · wemos/D1_mini_Examples · GitHub
nodencu v3 i copy script and cayenne no detect
what are you trying to do with nodemcu and analog input. Do you want to display the analog input value on the cayenne dashboard? which sensor you have connected to analog pin?
yes for all aswers
read water conductivity
@luisvaljun8 you need to provide more detail if you want some help. kindly provide some link to the sensor you are using.
this sensor
thank you. now follow this tutorial and see if you can get the reading from the sensor. once you get reading we will move to cayenne code. first try this Interface Moisture Sensor With NodeMCU : 7 Steps (with Pictures) - Instructables
yes read data
can you share the serial monitor output and code, so accordingly i can suggest the next step.
com4 9600
code is up post friend
i wanted to see the sensor value output in the serial monitor.
Next, you have add a new device to cayenne dashboard using Adding a New Device using MQTT
Once you device is connected, upload the below code,
char ssid[] = "ssid";
int sense_Pin = 0; // sensor input at Analog pin A0
int value = 0;
  Serial.print("MOISTURE LEVEL : ");
  value = analogRead(sense_Pin);
  value = value / 10;
  Serial.println(value);
  Cayenne.virtualWrite(1, value, "analog_sensor", "null");
