Help NewBie Connect Cayenne via EPS8266 Wifi Shield V1.0
Hello. I am new to Cayenne. Forgive me for my ignorance, I know this is probably the usual route into the Cayenne world. I am having trouble connecting with a Arduino Uno, staked with a breakout ESP8266 Wifi Shield. I have followed the step by step instruction but got an error - about “Serial1” was not declared in this scope"
I removed the “1” at the end, and the code compiled without an error.
I then uploaded it to my Arduino and I got an error (after a delayed uploading) - “Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.”
After several unsucessful attempts at resolving the issue, I disconnected the Arduino, removed the ESP8266 Wifi Shield and reconnected the Arduino to the computer via the USB. and I was then able to upload the sketch without an error. I then reattached the Wifi Shield and pressed the reset button…
but no cheese! Nothing is happening on the Cayenne Dashboard too.
I am running Windows 10 64Bit, IDE 1.6.7, Have installed CayenneMQTT Library, ESP8266MQTT, ESPSerialLibarary. my code is as below…
#include <ESP8266SerialLibrary.h>
char ssid[] = "SSID";
char wifiPassword[] = "123456";
char username[] = "<code from dash board>";
char password[] = "<code from dash board>";
char clientID[] = "<code from dash board>";
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(10);
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
What could I be doing wrong?
this library was made for esp8266 as shield for arduino mega which has Serial1 wheras arduino uno does not have. use software serial instead or try with this code.
char ssid[] = “xequebo”;
char wifiPassword[] = “0”;
char username[] = “0”;
char password[] = “0”;
char clientID[] = “0”;
unsigned long lastMillis = 0;
//Serial.begin(9600);
EspSerial.begin(9600);
delay(10);
  if (millis() - lastMillis > 500000) {
    lastMillis = millis();
    Cayenne.virtualWrite(2, lastMillis);
