I can’t figure out what I am missed here but I bought my 1st NODEMCU Amica ESP8266 and I am trying to connect to it using Cayenne.
Here is the code(credentials x’ed out) I am using which uploads fine to the device and I can see its on my wifi network but it does not show up in my devices in my app or online. It shows its still looking for it. Any ideas?
//#define CAYENNE_DEBUG
char ssid = “gggggggg”;
char wifiPassword = “tmih8iy51e2tn”;
char username = “xxxxxxx-xxxxxxx-1xxxxxx-axxxx-5xxxxxxxxxxxxxxxxxxx”;
char password = “4xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
char clientID = “4xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx9”;
unsigned long lastMillis = 0;
lastMillis = millis();
Cayenne.celsiusWrite(1, 22.0);
Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
