Help with mqtt
im using mqtt and the buttons work slowly. If i use button one after other arduino goes offline. I have succesfully converted code from old to new MQTT sensor also lag. please help i have to show project on monday.
#include <Ultrasonic.h>
char ssid[] = “zzzzz”;
char wifiPassword[] = “zzzzz”;
char username[] = “zzzzz-6624-11e7-9c17-adc0b1d0cf53”;
char password[] = “zzzzz”;
char clientID[] = “z-16f7-z-z-z”;
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
const int thermistorPin = 0;
const float resistance = 10000;
Thermistor thermistor(A0, 10000);
int led = LOW;
int led1 = LOW;
int led2 = LOW;
int led3 = LOW;
Ultrasonic ultrasonic(12, 13);
pinMode(3, OUTPUT); // button
pinMode(2, OUTPUT); // LED or relay
pinMode(4, OUTPUT);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_IN(1) {
int value = getValue.asInt();
digitalWrite(2, value);
CAYENNE_IN(2) {
digitalWrite(3, value);
CAYENNE_IN(3) {
digitalWrite(4, value);
CAYENNE_OUT(5)
Cayenne.celsiusWrite(5, thermistor.getCelsius());
delay(10);
CAYENNE_OUT(6)
Cayenne.virtualWrite(6, ultrasonic.distanceRead());
delay(10);
CAYENNE_OUT(7)
Cayenne.kelvinWrite(7, thermistor.getKelvin());
delay(10);
CAYENNE_OUT(8)
Cayenne.fahrenheitWrite(8, thermistor.getFahrenheit());
delay(10);
try this code. i made some small changes.
int led = LOW;
int led1 = LOW;
int led2 = LOW;
int led3 = LOW;
unsigned long lastMillis = 0;
pinMode(4, OUTPUT);
delay(10);
delay(10);
		lastMillis = millis();{
CAYENNE_IN(1) {
CAYENNE_IN(2) {
CAYENNE_IN(3) {
I’ll try it once I’m free
