Help with selecting a pin
Hello, I’m trying to add a thermisor, but the option to add the PIN is not available, what am I doing wrong?
My code
#define CAYENNE_PRINT Serial   // Comment this out to disable prints and save space
// If you're not using the Ethernet W5100 shield, change this to match your connection type. See Communications
examples.
#include <CayenneEthernet.h>
char token[] = "=D";
// Virtual Pin of the Thermistor widget.
#define VIRTUAL_PIN V1
// Analog pin the thermistor is connected to.
const int thermistorPin = 0;
// Resistance of the resistor. Currently set to 10k but this can be set to the measured resistance of your
// resistor for greater accuracy.
const float resistance = 10000;
Thermistor thermistor(thermistorPin, resistance);
	Cayenne.begin(token);
CAYENNE_OUT(VIRTUAL_PIN)
	Cayenne.celsiusWrite(VIRTUAL_PIN, thermistor.getCelsius());
	// To send the temperature in Fahrenheit or Kelvin use the corresponding code below.
	//Cayenne.fahrenheitWrite(VIRTUAL_PIN, thermistor.getFahrenheit());
	//Cayenne.kelvinWrite(VIRTUAL_PIN, thermistor.getKelvin());
Hi @Bruno_bls23,
Can you send a screenshot of what is the issue? It seems related to UI rather than code.
Thanks,
~Benny
So I tried it another way.
I added a thermistor, I used the ‘virtual’ sensor. But it now appears as offline on the dashboard.
I’m using the USB serial connection.
One question: do I always have to run the file “cayenne-ser.bat” when connected in this way?
Yes, you always have to have that script running.
