Home devices control system with cayenne
Home devices control system using Cayenne
This project is about controlling home devices through cayenne and Arduino. It is very easy to connect your devices with internet through Cayenne IOT solutions. I am very happy to post my first project using this amazing and unique service.In home devices control system, I have used two devices to control through internet by using Cayenne IOT server and trust me I completed this task in 5 minutes which in past took me more than 15 days to connect arduino with internet. So it makes my life so easy. Now I can connect my devices with internet with in minutes.
What’s Connected
In this we are using followng hardware components
Arduino
Ethernet shield
Relay module
load
##Circuit diagram
For demonstration purpose I have connected only one load, but we can connect as many loads as we want.
Dashboard Screenshots
user can simply press on and off button to turn and turn off device which is interfaced through and it is very easy to interface relay with Arduino
Video of project
##Code of project
#include <CayenneEthernet.h>
#define VIRTUAL_PIN1 1
#define VIRTUAL_PIN2 2
#define RELAY_DIGITAL_PIN1 4
#define RELAY_DIGITAL_PIN2 5
char token[] = "";
  // set digital pin to output
  pinMode(RELAY_DIGITAL_PIN1, OUTPUT);
  pinMode(RELAY_DIGITAL_PIN2, OUTPUT);
  Cayenne.begin(token);
CAYENNE_IN(VIRTUAL_PIN1)
  if (currentValue == 1) {
    digitalWrite(RELAY_DIGITAL_PIN1, HIGH);
  } else {
    digitalWrite(RELAY_DIGITAL_PIN1, LOW);
CAYENNE_IN(VIRTUAL_PIN2)
    digitalWrite(RELAY_DIGITAL_PIN2, HIGH);
  } else {
    digitalWrite(RELAY_DIGITAL_PIN2, LOW);
In code you just need to use, Cayenne_in function for different loads which is self explanatory. This is all about this project. I am very excited to post some advance projects with Cayenne services in coming days. :slight_smile:
Cool video!
You should be sure to submit this to the project contest, it’s ending soon!
how to submit project to content? I have already uploaded project on hackstar and instructables.
link of my article on hackstar https://www.hackster.io/bilal-malik/home-devices-control-system-with-cayanne-c29ca9
link of my article on instructables http://www.instructables.com/id/Home-Devices-Control-System-With-Cayanne/
I will also post new projects in content before 31 october
