How can i convert this code into an widget for cayenne
The code below demonstrate an MQ135 gas sensor detecting CO2 in the air in the unit PPM. I am trying to make these values display on my phone using cayenne while my arduino is connected serial with an usb.
int sensorValue;
float vol;
Serial.println("");
sensorValue = analogRead(A0);
Serial.print(“PPM =”);
Serial.print(sensorValue);
delay(1000);
have a look at this https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/SerialUSBConnection/SerialUSBConnection.ino
but it is bit difficult to use serial usb connection, so i would suggest getting a ethernet or wifi shield and then connect to cayenne.
