How do I link my MPU6050 to cayenne?
I have a MPU6050 3 axis accel/ 3 axis gyro (has an onboard ADC) that I have working on python and wanted to use this with cayenne.
How would I set up cayenne to allow communication?
I currently have the MPU6050 wired to sda (pin 3) and scl (pin5)
Hi again @hoang.tony.p,
Good to see you around! Unfortunately, it is not possible right now. We will be releasing Arduino integration soon, then we will work on giving users the ability to bring on any device for Raspberry Pi. This way, you are not waiting on the Cayenne team to integrate devices into the system. Hope this helps!
Is there an ETA for arduino integration? Thanks
This upcoming week :slight_smile:
Hi, I know this is an old post but interested if you found a solution to get the MPU6050 to communicate with Cayenne? Thanks.
which device are you using to connect to cayenne. we can try together to send MPU6050 value to cayenne.
Thank you for responding! I’m using an ESP 8266. I am able to connect to Cayenne with this board and am sending temp and humidity data.
can you share the code and a link to the ESP8266 board.
link to board:
//this is the code I’m using to connect to Cayenne to send temp and humidity ( I removed wifi and Cayenne authentication info)
//#define CAYENNE_DEBUG
#include <DHT.h>
char ssid[] = “”;
char wifiPassword[] = “”;
char username[] = “”;
char password[] = “”;
char clientID[] = “”;
DHT dht(D2, DHT11);
float temp = dht.readTemperature(true); //Fahrenheit
float hum = dht.readHumidity();
Cayenne.virtualWrite(1, temp, TYPE_TEMPERATURE, UNIT_FAHRENHEIT);
Cayenne.virtualWrite(2, hum, TYPE_RELATIVE_HUMIDITY, UNIT_PERCENT);
I tried editing the code I found here at this Cayenne Community link to use with the board I’m using including revising code to MQTT format.
were you succesfull at it?
no, I could not make that code work.
#14
can you post the code. before that try connecting MPU6050 to nodemcu and code without cayenne lines. just to check whether you are getting reading from MPU6050.
#16
the following is a stripped down version of the sketch file I was editing. I removed the math calculations from the code. I was basically trying to edit the code down enough just to get board to connect to Cayenne. I am a beginner to all of this (less than 2 weeks) so I’m sure there are coding errors and omissions in this example. I left the dht11 temp/humidity code in the sketch but I don’t really need it. My main goal is to get the x/y/z data to the Cayenne dashboard via wifi board.
#include <DHT.h>
#include <Wire.h>
#include <Math.h>
#include <I2Cdev.h>
#include <MPU6050.h>
//#define VIRTUAL_PINX V2
const int VIRTUAL_PINX = 3;
//#define VIRTUAL_PINY V3
const int VIRTUAL_PINY = 4;
MPU6050 accelerometer;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
DHT dht(D2, DHT11);
    Wire.begin();
    accelerometer.initialize();
 float angle_x = accelerometer.getAcceleration();
 Cayenne.virtualWrite(3, angle_x);
// Cayenne.virtualWrite(4, angle_y);
#17
these are the errors from the Audrino IDE;
Arduino: 1.8.5 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
C:\Users\Documents\Arduino\MyESP8266ODHT11AXIS\MyESP8266OfficeDHT11MPU6050\MyESP8266OfficeDHT11MPU6050.ino: In function ‘void loop()’:
MyESP8266OfficeDHT11MPU6050:48: error: no matching function for call to ‘MPU6050::getAcceleration()’
C:\Users\Documents\Arduino\MyESP8266ODHT11AXIS\MyESP8266OfficeDHT11MPU6050\MyESP8266OfficeDHT11MPU6050.ino:48:48: note: candidate is:
In file included from C:\Users\Documents\Arduino\MyESP8266ODHT11AXIS\MyESP8266OfficeDHT11MPU6050\MyESP8266OfficeDHT11MPU6050.ino:11:0:
C:\Users\Documents\Arduino\libraries\MPU6050/MPU6050.h:625:14: note: void MPU6050::getAcceleration(int16_t*, int16_t*, int16_t*)
     void getAcceleration(int16_t* x, int16_t* y, int16_t* z);
C:\Users\Documents\Arduino\libraries\MPU6050/MPU6050.h:625:14: note: candidate expects 3 arguments, 0 provided
Multiple libraries were found for “CayenneMQTTESP8266.h”
Used: C:\Users\Documents\Arduino\libraries\CayenneMQTT
Not used: C:\Users\Documents\Arduino\libraries\Cayenne-MQTT-ESP-master
Multiple libraries were found for “Adafruit_Sensor.h”
Used: C:\Users\Documents\Arduino\libraries\Adafruit_Sensor-master
Not used: C:\Users\Documents\Arduino\libraries\Adafruit_Unified_Sensor
exit status 1
option enabled in File -> Preferences.
#18
try this code and see if you get reading. check your serial monitor for reading.
#include "Wire.h"
#include "Math.h"
#include "I2Cdev.h"
#include "MPU6050.h"
const float pi = 3.141592;
const int avg_max = 100;
int16_t ax, ay, az;
float x, y, z;
int avg_count;
float _angle_x, angle_x, _angle_y, angle_y;
long ax_avg, ay_avg, az_avg;
    Wire.begin();
    if (accelerometer.testConnection()) {
        Serial.println("Accelerometer Connected...");
    //read accelerometer
    accelerometer.getAcceleration(&ax, &ay, &az);
    //accumulate averages
    ax_avg = ax_avg + ax;
    ay_avg = ay_avg + ay;
    az_avg = az_avg + az;
    avg_count++;
    //got all the sample?
    if (avg_count == avg_max)
     //calculate averages
     x = ax_avg/avg_max;
     y = ay_avg/avg_max
     z = az_avg/avg_max
     //compute angles
     angle_x = atan2(x, sqrt(square(y) + square(z))      )/(pi/180);
     angle_y = atan2(y, sqrt(square(x) + square(z))      )/(pi/180);
     //initialize for next pass
     avg_count = 0;
     ax_p = 0;
     ay_p = 0;
     az_p = 0;
    //print results
    Serial.print(angle_x);
    Serial.print("\t");
    Serial.println(angle_y);
#19
this line of code
got this error when compiling
C:\Users\Documents\Arduino\MyESP8266ODHT11AXIS\sketch_may07a\sketch_may07a.ino: In function ‘void loop()’:
sketch_may07a:45: error: ‘square’ was not declared in this scope
sketch_may07a:50: error: ‘ax_p’ was not declared in this scope
  ax_p = 0;
sketch_may07a:51: error: ‘ay_p’ was not declared in this scope
  ay_p = 0;
sketch_may07a:52: error: ‘az_p’ was not declared in this scope
  az_p = 0;
exit status 1
#20
do some google search and find ways to connect MPU6050 to nodemcu.
#21
have a look at this http://www.electronicwings.com/nodemcu/mpu6050-interfacing-with-nodemcu
