How include two PH sensors in cayenne?
Hi there.
A few days ago, my friend Tad.dvor, helped me a include a PH sensor in cayenne. And now I would like add two ph sensors in cayenne.
I’m use this code below to add one sensor
#include <CayenneEthernet.h>
#define SensorPin 0 //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00 //deviation compensate
unsigned long int avgValue; //Store the average value of the sensor feedback
float phValue;
char token[] = "token";
  Cayenne.begin(token);
  int buf[10]; //buffer for read analog
  for(int i=0;i<10;i++) //Get 10 sample value from the sensor for smooth the value
    buf[i]=analogRead(SensorPin);
    delay(10);
  for(int i=0;i<9;i++) //sort the analog from small to large
    for(int j=i+1;j<10;j++)
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
  avgValue=0;
  for(int i=2;i<8;i++) //take the average value of 6 center sample
  avgValue+=buf[i];
  phValue=(float)avgValue*5.0/1024/6; //convert the analog into millivolt
  phValue=3.5*phValue+Offset; //convert the millivolt into pH value
CAYENNE_OUT(V0)
  Cayenne.virtualWrite(V0, phValue);
And I was trying this code to add two sensor
#define VIRTUAL_PIN V0
#define VIRTUAL_PINB V1
float phValue;
//Sobre sensor B
#define SensorPinB 2 //pH meter Analog output to Arduino Analog Input 0
unsigned long int avgValueB;
#define OffsetB 0.00 //deviation compensate
float phValueB;
char token[] = "mrl1myalp4";
    delay(10);
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
         avgValue=0;
  avgValue+=buf[i];
    buf[i]=analogRead(SensorPinB);
    delay(10);
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
  avgValueB=0;
  avgValueB+=buf[i];
  phValueB=(float)avgValueB*5.0/1024/6; //convert the analog into millivolt
  phValueB=3.5*phValueB+OffsetB; //convert the millivolt into pH value
CAYENNE_OUT(V0)
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1, phValueB);
But the second sensor give-me absurd values.
Thank you.
Try this:
#define SensorPin0 A0 //pH meter Analog output to Arduino Analog Input 0
#define SensorPin1 A1 //pH meter Analog output to Arduino Analog Input 1
unsigned long int avgValue0; //Store the average value of the sensor feedback
unsigned long int avgValue1; //Store the average value of the sensor feedback
float phValue0;
float phValue1;
    buf[i]=analogRead(SensorPin0);
    delay(10);
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
  avgValue0=0;
  avgValue0+=buf[i];
  phValue0=(float)avgValue0*5.0/1024/6; //convert the analog into millivolt
  phValue0=3.5*phValue0+Offset; //convert the millivolt into pH value
    buf[i]=analogRead(SensorPin1);
    delay(10);
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
  avgValue1=0;
  avgValue1+=buf[i];
  phValue1=(float)avgValue1*5.0/1024/6; //convert the analog into millivolt
  phValue1=3.5*phValue1+Offset; //convert the millivolt into pH value
CAYENNE_OUT(V0)
  Cayenne.virtualWrite(V0, phValue0);
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1, phValue1);
I’m appreciate. Thank’s again Tad.dvor. :thumbsup:
