We’re designing some new widgets, would love to get your input here.
What’s your use case for a Joystick Widget?
What are your expectations when using this widget?
Thanks in advance!
Thanks in advance!
The first thing that comes to mind is a camera gimbal done with 2 servos. So the set up would be access to 2 pwm channels with the option to invert the logic. A camera widget would be very handy for this
Movement accelerates as your finger moves away from the center of the ‘joystick’ icon.
Ian
The only ‘joystick’ I woud be using at the monet would be the Pi SenseHAT one and simply to act as direction buttons and a tap button (e.g. D-Pad but with a tap down as well).
Also as select/scroll buttons in a menu list sort of thing.
