How to assemble?
In my project i have a lot of captor.
How to assemble him ?
Example : (Thermometer + Lamp
char username[] = “//”;
char password[] = “//”;
char clientID[] = “//”;
#define SENSOR_PIN 0
#define VIRTUAL_CHANNEL 3
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
// This function is called at intervals to send sensor data to Cayenne. //Lamp
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN));
// This function is called when data is sent from Cayenne. //Thermometer
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
I try like this but it does’nt work.
change this :
to
#define VIRTUAL_CHANNEL_0 3
#define VIRTUAL_CHANNEL_1 2
in your entire code
Thanks you man ! ^^
:frowning:
Whats is the problem…?
just remove that line CAYENNE_LOG
I’m triying
Mhh… :confused:
made changes to your code.
char username[] = "";
char password[] = "";
char clientID[] = "";
#define VIRTUAL_CHANNEL_1 3
#define VIRTUAL_CHANNEL_2 2
CAYENNE_OUT(VIRTUAL_CHANNEL_1)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_1, analogRead(SENSOR_PIN));
CAYENNE_IN(VIRTUAL_CHANNEL_2)
Thx I’m triying
EDIT : Its work ! Thx ^^
I took the same example to add a actuator but i have a conflict whit my lamp.
When i turn on my new actuator (A fan), my lamp turn on and my fan don’t on.
When i turn on my lamp, my lamp on correctly.
can you post the code.
char username[] = "//";
char password[] = "//";
char clientID[] = "//";
#define VIRTUAL_CHANNEL_4 4
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define SENSOR_PIN 3
// This function is called at intervals to send sensor data to Cayenne. //Thermo
// This function is called when data is sent from Cayenne. //Lampe
// This function is called when data is sent from Cayenne. //Ventilateur
CAYENNE_IN(VIRTUAL_CHANNEL_4)
give this a try
#define ACTUATOR_PIN_1 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define ACTUATOR_PIN_2 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
pinMode(ACTUATOR_PIN_1, OUTPUT);
pinMode(ACTUATOR_PIN_2, OUTPUT);
int value= getValue.asInt();
digitalWrite(ACTUATOR_PIN_1, value);
  int value_1 = getValue.asInt();
  digitalWrite(ACTUATOR_PIN_2, value_1);
Thx :yum:
Good bye ^^
but i hope you are not just copying and pasting the code. try to understand and learn from the mistake you have made till now. anyways best of luck with your project.
#14
Don’t worry, I studied and understood
