How to change temperature upload period and put the ENC28J60 ethernet to sleep?
I use DS18B20 sensor, ENC28J60 ethernet module and Arduino MEGA. I want this system to last many years. Ethernet is operating on 40-70C so I don’t think it will last many years (my opinion). So I want to upload temperatures and put the module to sleep for 1 hour.
  1. How to upload only one temperature value once and not periodically?
  2. How to send ENC28J60 module (not shield) to deep sleep?
    For this example you need UIPEthernet library:
    https://github.com/ntruchsess/arduino_uip
    Wire it up:
    VCC - 3.3V
    GND - GND
    SCK - Pin 52
    SO - Pin 50
    SI - Pin 51
    CS - Pin 53
    #include <CayenneDefines.h>
    #include <UIPEthernet.h>
    #include <BlynkSimpleUIPEthernet.h>
    #include <CayenneEthernetClient.h>
    #include <OneWire.h>
    #define VIRTUAL_PIN V1
    boolean temp_uploaded=0;
    const int tmpPin = 3;
    OneWire oneWire(tmpPin);
    char token[] = “”; //NOT MY TOKEN
    Cayenne.begin(token);
    sensors.begin();
    CAYENNE_OUT(VIRTUAL_PIN)
    Cayenne.celsiusWrite(VIRTUAL_PIN, (random() % 100));
    Serial.println(“Temp updated”);
    temp_uploaded=1;
Hello Sir,
you can use:
static void 	powerDown ()
 	Put ENC28J60 in sleep mode.
static void 	powerUp ()
 	Wake ENC28J60 from sleep mode.
I recommend to read this article: http://blog.derouineau.fr/2011/07/putting-enc28j60-ethernet-controler-in-sleep-mode/
