How to delete triggers
    PI 3
Using Web & Android
Deleted my test PI and all the triggers are still there but I can’t change or delete them as it says device has been removed and triggers are disabled.
Did you try :
user menu > triggers > then editing the trigger you created > delete.
Yes this works. I had to use my computer as my tablet didn’t show the bottom row which has the delete button on it.
Thanks,
