How to make a switch so that a slider works on the 8266
how I would like a little bit of your help, I’m trying to make a sitch to be able to run a slidder, but I can not do it … I have this programming but I do not know how to do it … someone to help me please
I was trying to put conditional but I do not think I’m doing, because when channel 1 is on you should take the values ​​of the slidder but it does not work
Welcome to cayenne community @jorge_quishpe194 , your code should work fine once you initialize sliderValue and sli globally. can you copy and paste your code here in place of the sending a photo.
thanks for your help… but it dont works…
here my code
  pinMode(4,OUTPUT);
  pinMode(5, OUTPUT);
  int sli;
int sliderValu;
  Cayenne.virtualWrite(0, analogRead(A0));
  Cayenne.virtualWrite(2, analogRead(A0));
  delay(250);
CAYENNE_IN(3) //choose a free virtual channel … there are many
int sliderValue = (getValue.asInt());
analogWrite(5, sliderValue);
CAYENNE_IN(1)
  int i=getValue.asInt();
digitalWrite(4,i);
if (i==1)
  int sli = sliderValue;
  analogWrite(2, sli);
try this code:
unsigned long lastMillis = 0;
int i;
int sli;
int sliderValue;
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  if (i == 1)
    sli = sliderValue;
    lastMillis = millis();
    delay(250);
CAYENNE_IN(1)
  i = getValue.asInt();
  digitalWrite(4, i);
THANK YOU !!! :smile: your code help me… it works fantastic…
can i ask you another favor… I try to connect with my cellphone, but i cant…Do I need to be connected to the same network? or what do I do?
it works anywhere in the world, if you have an internet connection.
i ask it because when i try to control the slidder show me a message
and i don’t know what is the problem because the button works and the slider do not
the slider on the App is defect, The team working to solve it.
i didnt know it… thanks for the help…
till this bug is fixed you can try this. if you are using android app then you can make a project and open the shared link on mobile google chrome browser in desktop mode.
like this : Read Only Dashboard?
I understand … Thanks
