Hi there, I am trying to use Cayenne with my temperature sensor. Similar to TMP36 but it is TMP37, i cant seem to run my program to dashboard as it is not of the same sensor so am i suppose to change something on my code or customize my widget? Thanks in advance.
The sensor is not the problem. The TMP37 is the same as the TMP36 except:
“The TMP37 is intended for applications over the range of 5°C to 100°C and provides an output scale factor of 20 mV/°C.”
In fact with not sensor attached, you should still see “data” as the output is analogue.
Check code and wifi/ethernet connection
It would be helpful if you post your code and then we can go from there
hi there @bestes,
here’s my code.
//#include <CayenneEthernet.h>
#include <CayenneWiFi.h>
char token[] = "vgob9w51cx";
char ssid[] = "SSID" ;
char password[] = "PASSWORD" ;
// Virtual Pin of the TMP36 widget.
#define VIRTUAL_PIN V1
// Analog pin the TMP36 is connected to.
const int tmpPin = 0;
// Voltage to the TMP36. For 3v3 Arduinos use 3.3.
const float voltage = 5.0;
//must i change TMP36 to TMP37?
TMP36 tmpSensor(tmpPin, voltage);
CAYENNE_OUT(VIRTUAL_PIN)
Cayenne.celsiusWrite(VIRTUAL_PIN, tmpSensor.getCelsius());
// To send the temperature in Fahrenheit or Kelvin use the corresponding code below.
//Cayenne.fahrenheitWrite(VIRTUAL_PIN, tmpSensor.getFahrenheit());
//Cayenne.kelvinWrite(VIRTUAL_PIN, tmpSensor.getKelvin());
may I know am i suppose to change the TMP36? I am very new to this, I hope you can guide me along. Thanks in advance!
Hi @nurhazirh ,
We actually have a guide specifically for connecting a TMP36 sensor to an Arduino! You can read about it here:
http://www.cayenne-mydevices.com/docs/#getting-started-arduino-sensors
Hope this helps!
