How to run cayenne continously with heart pulse in my code?
i need cayenne to work countinously with the amped heart sensor,i used the instruction cayenne.run();
but i have the following problem error: ‘class CayenneMQTTWiFiClient’ has no member named ‘run’
could you help me with that?
Nodemcu heartbeat monitor
Cayenne.run() is for old library. You need to use Cayenne.loop()
i used cayenne.loop(); and y code is compiled well but nothing appears on cayenne or either lcd,here is my code:
//libraries
#include <Ticker.h>
#include <SPI.h>
#include <Wire.h>
#include <LiquidCrystal.h>
#include <ESP8266WiFi.h>
#include "CayenneDefines.h"
// identify function
void   interruptSetup();
char ssid[] = "ramia.m";
char wifiPassword[] = "0933am471100am+";
char username[] = "";
char password[] = "";
char clientID[] = "";
// The Ticker/flipper routine
Ticker flipper;
//  VARIABLES
int blinkPin = 15;                // pin to blink led at each beat
int fadePin = 13;                 // pin to do fancy classy fading blink at each beat
int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM;                   // used to hold the pulse rate
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // holds the time between beats, must be seeded!
volatile boolean Pulse = false;     // true when pulse wave is high, false when it's low
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
//lcd
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 5, en = 4, d4 = 0, d5 = 2, d6 = 14, d7 = 12;
LiquidCrystal lcd(rs, en, d4,d5,d6,d7);
void setup(){
lcd.begin(16, 2);
delay(20);
delay(10);
WiFi.begin(ssid,wifiPassword);
lcd.clear() ;
lcd.print("Haya & Marie");
delay(2000);
lcd.clear() ;
lcd.print('.');
delay(1000);}
lcd.clear() ;
lcd.print("connected via IP: ");
delay(500);
lcd.clear();
lcd.println(WiFi.localIP());
delay(1000);
// Clear the buffer.
lcd.clear() ;
//lcd.print("ssss");
//cayenne new
//#define EspSerial Serial1
pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
pinMode(fadePin,OUTPUT);          // pin that will fade to your heartbeat!
Serial.begin(9600);             // we agree to talk fast!
interruptSetup();
// sets up to read Pulse Sensor signal every 2mS
void loop(){
lcd.clear() ;
lcd.print(" BPM = ");
lcd.print(BPM);
delay(1000);
//        lcd.clear() ;
//        lcd.print("  IBI = ");
//        lcd.print(IBI);
//        delay(500);
lcd.clear() ;
sendDataToProcessing('S', Signal);     // send Processing the raw Pulse Sensor data
if (QS == true){                       // Quantified Self flag is true when arduino finds a heartbeat
fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
sendDataToProcessing('B',BPM);   // send heart rate with a 'B' prefix
sendDataToProcessing('Q',IBI);   // send time between beats with a 'Q' prefix
QS = false;                      // reset the Quantified Self flag for next time
ledFadeToBeat();
delay(10);
//  take a break
void ledFadeToBeat(){
fadeRate -= 15;                         //  set LED fade value
fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going into negative numbers!
analogWrite(fadePin,fadeRate);          //  fade LED
void sendDataToProcessing(char symbol, int data ){
Serial.print(symbol);                // symbol prefix tells Processing what type of data is coming
Serial.println(data);                // the data to send culminating in a carriage return
volatile int rate[10];                    // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;  // used to find IBI
volatile int P =512;                      // used to find peak in pulse wave, seeded
volatile int T = 512;                     // used to find trough in pulse wave, seeded
volatile int thresh = 512;                // used to find instant moment of heart beat, seeded
volatile int amp = 100;                   // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false;      // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
// Initializes Ticker to have flipper run the ISR to sample every 2mS as per original Sketch.
flipper.attach_ms(2, ISRTr);
// THIS IS THE TICKER INTERRUPT SERVICE ROUTINE.
// Ticker makes sure that we take a reading every 2 miliseconds
void ISRTr(){                         // triggered when flipper fires....
cli();                               // disable interrupts while we do this
Signal = analogRead(A0);              // read the Pulse Sensor
sampleCounter += 2;                         // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
//  find the peak and trough of the pulse wave
if(Signal < thresh && N > (IBI/5)*3){       // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T){                        // T is the trough
T = Signal;                         // keep track of lowest point in pulse wave
if(Signal > thresh && Signal > P){          // thresh condition helps avoid noise
P = Signal;                             // P is the peak
}                                        // keep track of highest point in pulse wave
//  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250){                                   // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
Pulse = true;                               // set the Pulse flag when we think there is a pulse
digitalWrite(blinkPin,HIGH);                // turn on pin 13 LED
IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
lastBeatTime = sampleCounter;               // keep track of time for next pulse
if(secondBeat){                        // if this is the second beat, if secondBeat == TRUE
secondBeat = false;                  // clear secondBeat flag
for(int i=0; i<=9; i++){             // seed the running total to get a realisitic BPM at startup
rate[i] = IBI;
if(firstBeat){                         // if it's the first time we found a beat, if firstBeat == TRUE
firstBeat = false;                   // clear firstBeat flag
secondBeat = true;                   // set the second beat flag
sei();                               // enable interrupts again
return;                              // IBI value is unreliable so discard it
// keep a running total of the last 10 IBI values
word runningTotal = 0;                  // clear the runningTotal variable
for(int i=0; i<=8; i++){                // shift data in the rate array
rate[i] = rate[i+1];                  // and drop the oldest IBI value
runningTotal += rate[i];              // add up the 9 oldest IBI values
rate[9] = IBI;                          // add the latest IBI to the rate array
runningTotal += rate[9];                // add the latest IBI to runningTotal
runningTotal /= 10;                     // average the last 10 IBI values
BPM = 60000/runningTotal;               // how many beats can fit into a minute? that's BPM!
QS = true;                              // set Quantified Self flag
// QS FLAG IS NOT CLEARED INSIDE THIS ISR
if (Signal < thresh && Pulse == true){   // when the values are going down, the beat is over
digitalWrite(blinkPin,LOW);            // turn off pin 13 LED
Pulse = false;                         // reset the Pulse flag so we can do it again
amp = P - T;                           // get amplitude of the pulse wave
thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
P = thresh;                            // reset these for next time
T = thresh;
if (N > 2500){                           // if 2.5 seconds go by without a beat
thresh = 512;                          // set thresh default
P = 512;                               // set P default
T = 512;                               // set T default
lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
firstBeat = true;                      // set these to avoid noise
secondBeat = false;                    // when we get the heartbeat back
Cayenne.virtualWrite(V13, BPM , "analog_sensor", "null");
sei();                                   // enable interrupts when youre done!
}// end isr
Follow this tutorial and first get your device connected to cayenne Adding a New Device using MQTT
