How to trigger a script on pi 3?
just copy and paste here. i cannot access your link.
#!/usr/bin/env python
from picamera import PiCamera
from time import sleep
import RPi.GPIO as GPIO
import datetime
camera = PiCamera()
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN) #PIR
camera.rotation =180 # flip the pic
import cayenne.client
import time
x = 0
# Cayenne authentication info. This should be obtained from the Cayenne Dashboa$
#MQTT_USERNAME  = ""
#MQTT_PASSWORD  = ""
#MQTT_CLIENT_ID = ""
def on_message(message):
    global x
    # If there is an error processing the message return an error string, other$
    if (message.channel == 4) and (message.value == "1"):
        print("button is pressed")
        x = 1
    if (message.channel == 5) and (message.value == "1"):
        print("quit button is pressed")
        quit()
    indent preformatted text by 4 spaces
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, port=8883)
i=0
timestamp = 0
motion = False
motioncounter = 0
while True:
client.loop()
if motion:
motioncounter += 1
if (not motion) or (motioncounter > 50):
if motioncounter > 50:
motioncounter = 0
if GPIO.input(18):
print(ā€œMotion Detectedā€¦ā€)
dt = datetime.datetime.now()
fn = ā€˜{:/home/pi/mqtt/examples/pic/%Y%m%dT%H%M%S.jpg}ā€™.format(dt)
client.virtualWrite(2,1,ā€œdigital_sensorā€,ā€œdā€)
camera.start_preview()
#time.sleep(5) ####If you really do need a delay here make it less $
camera.capture(fn)
camera.capture(ā€˜/home/pi/Desktop/image.jpgā€™)
        camera.stop_preview()
        motion = True
        motioncounter = 0
    else:
            print("making two state zero")
            client.virtualWrite(2,0,"digital_sensor","d")
            timestamp = time.time()
            motion = False
time.sleep(0.1)
this is because the button channel is 5 and when channel 5 becomes 1 it runs:
which shutdown the raspberry pi.
when adding a button select channel as 6.
Yes,that is correct, but I added a new widget on channel 7 with a trigger that should send an email.
When I press this widget, the pi keep running, but no email is sent, and the trigger run 0 times
sir,Would you mind sharing you account with me ? You can PM me your login and password and change your password here if you need. https://cayenne.mydevices.com/cayenne/forgot
It is Devise 2346
Now the triggers are working for motion and button.
Very good.Then I can start my project.
Now it is time to test if also sms is working.
ā€¦
Yes it is working ā€¦yipppi
once done, share the project with community.
