Huzzah Analog pin
Anyone know how to specify a luminosity sensor on Analog pin A on a huzzah?
It should be like an Arduino:
int lumens = analogRead(A0);
From the site of the adafruit: This pin has a ~1.0V maximum voltage, so if you have an analog voltage you want to read that is higher, it will have to be divided down to 0 - 1.0V range
Thanks for the 1v max reminder. I may have damaged it already, I’ll try another board.
So sad. :frowning:
I’m pretty sure I’ve fed in more than 1v (less than 3.3v) on this pin and it was fine, just didn’t read anything over 1v. I would recommend trying less than 1v to verify it will works.
I had the digital read in the wrong place. Needs to be inside the particular Cayenne Out ().
