I can't connct any thing
Hi @mahmoudhevar
Hang tight for a moment as the whole platform is in maintenance mode. If you just tried to add something, I’d expect it to fail (you’re probably not really logged in anymore, even if the site hasn’t showed that). As soon as we’re back up and running, I’ll update and you can try again.
Ok, thank you for your patience. If you didn’t see in the other thread, our outages have been resolved.
Give it another shot, and if your still device doesn’t connect, let us know some detail (what is the device, what sort of error messages or state you’re seeing, etc) and we’ll help troubleshoot!
