I can't install cayenne in raspberry pi 2
Apparently I have everything well connected but no cayenne is not installed.
I leave the text of the message and I hope help
Thank you so much
pi@raspberrypi ~ $ sudo bash rpi_f0p65dl4fs.sh -v
rpi_f0p65dl4fs.sh
dir exists
grep: /etc/myDevices/AppSettings.ini: No existe el fichero o el directorio
Invite code does not exist but directory does so we will add invite code
rpi_f0p65dl4fs.sh:línea 14:/etc/myDevices/AppSettings.ini: No existe el fichero o el directorio
rpi_f0p65dl4fs.sh: línea 15: /etc/myDevices/AppSettings.ini: No existe el fichero o el directorio
rpi_f0p65dl4fs.sh: línea 16: /etc/myDevices/AppSettings.ini: No existe el fichero o el directorio
myDevices: unrecognized service
this is de operaating system
pi@raspberrypi ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs
HI @manrobles and welcome to the Cayenne community!
This is likely because you’re running Raspbian 7 (wheezy) on your Raspberry Pi where we only support Raspbian 8 (Jessie and Jessie Lite) at this time. I would suggest to download the latest Raspbian OS and re-image your SD card to it, then try Cayenne installation again.
I suspect you will not see any further errors if you do so, but feel free to post here if you do and I’ll continue to help troubleshoot.
