I cant rid of arduino
When i look around in dashboard i select Add new / device/widget / Microcontrollers/Arduino… (Step 2: Set up your Arduino)…
Problem is that there is no BACK buton (just NEXT) and on the top left side of dashboard Arduino (with sand clock) text appers… How can i undo this operation?
Okey, it si very simple. Just click “NEXT” and the you will see the “REMOVE” button. :slight_smile: Hope it helps :slight_smile:
