I have no readout on my ds18b20 I have the correct slave address
Im have major issues with my ds18b20 sensor. I had everything setup with triggers awhile ago and everything is messed up
can you post what error you are getting.
shramiksalgaonkar
Regular
    February 20
follow the steps from here Converting Cayenne Arduino LIbrary sketches to Cayenne MQTT Arduino and update your mobile app.
Even though Iā€™m using a raspberry pi?
sorry, @jcruz1 can help you out with this.
Hi @scottlandfarm,
Sorry for the delays.
Are you seeing the same errors while logging on through a desktop?
If possible, can you PM me your login, so we can take a look from our side?
Thanks.
-Jesse
Hi @scottlandfarm,
I tried to duplicate the issue on our side but unable to. I setup a RPi with a DS18B20 sensor and was working as expected.
Make sure you have everything connected properly. You can use this as a reference: https://mydevices.com/cayenne/docs_stage/supported-hardware/#supported-hardware-sensors-temperature-ds18b20
If everything is connected correctly, the widget should pop up on its own. No need to manually add it.
Let us know how it goes.
Thanks.
-Jesse
My login info is sxxxxxxxxxx@gmail.com and the password is xxxxxxxxxx
Hi @scottlandfarm,
As I mentioned in my previous post, for this specific sensor, you do not manually add it. If the RPi detects the sensor on the 1-wire pin (Physical pin 7 - see below), & you have everything wired in correctly, the RPi will automatically send the sensor data to the dashboard. The widget will pop up on its own.
Can you give us a picture and description on how you have it wired up?
Thanks.
-Jesse
jcruz
    February 22
Hi @scottlandfarm,
Thanks.
-Jesse
jcruz
    February 22
Hi @scottlandfarm,
Thanks.
-Jesse
#14
Hey @scottlandfarm sorry for digging up an old thread, but were you able to get this working or do you still need some help with it?
#15
Yes, I reinstalled raspbian. Thank you
