I need help and am new to Arduino
I am trying to get the relays to work on a smart thermostat I am trying to design. The code is below and I hope someone can help me.
// Generated with a lot of love//
// with TUNIOT FOR ESP8266     //
// Website: Easycoding.tn      //
#include <ESP8266WiFi.h>
#include "DHT.h"
#include "CayenneDefines.h"
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 6 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define CAYENNE_DEBUG
#include <CayenneMQTTESP8266.h>//IMPPORT LIBRARY FROM http://easycoding.tn/index.php/resources/
char Cayenneusername[] = "XXX";
char Cayennepassword[] = "YYY";
char CayenneclientID[] = "ZZZ";
DHT dht5(5,DHT22);
//For Serial Display
#include <Wire.h>
#include <SPI.h>
#include "SH1106.h"
#include "SH1106Ui.h"
// For DHT Tester
#include "DHT.h"
#define DHTPIN 5     // what digital pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
#define OLED_RESET  D1   // RESET
#define OLED_DC     D2   // Data/Command
#define OLED_CS     D8   // Chip select
// Uncomment one of the following based on OLED type
SH1106 display(true, OLED_RESET, OLED_DC, OLED_CS); // FOR SPI
//SH1106   display(OLED_ADDR, OLED_SDA, OLED_SDC);    // For I2C
SH1106Ui ui     ( &display );
  WiFi.disconnect();
  delay(3000);
  Serial.println("START");
   WiFi.begin("XXX","1111111122");
  while ((!(WiFi.status() == WL_CONNECTED))){
delay(300);
Serial.print("..");
  Serial.println("Connected");
  Serial.println("Your IP is");
  Serial.println((WiFi.localIP().toString()));
  Cayenne.begin(Cayenneusername, Cayennepassword, CayenneclientID);
Cayenne.virtualWrite(0,(dht5.readTemperature(true)));
Cayenne.virtualWrite(1,(dht5.readHumidity(true)));
  delay(1000);
// Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
display.init();
  display.setTextAlignment(TEXT_ALIGN_LEFT);
  display.setFont(ArialMT_Plain_10);
  display.drawString(0, 0, "C-ra Thermostat 1 Results");
  display.display();
  display.drawString(0, 32, "Temp:  " + String(f) + " *F");
  display.display();
  display.drawString(0, 16, "Humidity:  " + String(h) + " %");
  display.display();
  display.drawString(0, 48, "Heat index:  " + String(hif) + " *F");
  display.display();
delay(15000);
CAYENNE_IN(V0)
// initialize digital pin 2 as an output.
  pinMode(D3, OUTPUT);
  pinMode(D4, OUTPUT);
  pinMode(D9, OUTPUT);
  // This function will be called every time a Dashboard widget writes a value to Virtual Pin 2.
  CAYENNE_LOG("Got a value: %s", getValue.asStr());
  int i = getValue.asInt();
  if (i == 0)
digitalWrite(D0, HIGH);
  else
digitalWrite(D0, LOW);
  if (i == 0)
digitalWrite(D1, HIGH);
  else
digitalWrite(D1, LOW);
  if (i == 0)
digitalWrite(D2, HIGH);
  else
digitalWrite(D2, LOW);
By the way, I am using an ESP 8266
what is the issue you are facing? you can have a look at this Adding a New Device using MQTT
I had a look at the link Add in a New Device Using MQTT and it could not help me. I revised the sketch and it compiles without error but it still will not get the values and turn on the relay. He is the code I am using.
#include "DHT.h"
DHT dht5(5,DHT22);
#include <Wire.h>
#include <SPI.h>
#include "SH1106.h"
// For DHT Tester
#include "DHT.h"
  WiFi.disconnect();
  delay(3000);
   WiFi.begin("XXX","111112222");
    delay(300);
    Serial.print("..");
    /*Cayenne.virtualWrite(1,dht5.readHumidity(true),"temp","f")*/
    delay(1000);
    return;
display.init();
  display.display();
  display.display();
  display.display();
  display.display();
delay(15000);
 // This function will be called every time a Dashboard widget writes a value to Virtual Channel 0.
CAYENNE_IN(0)
  // You can also use:
  // double d = getValue.asDouble()
  if (i >= 0)
    Serial.println(i);
    digitalWrite(D4, HIGH);
  else
    Serial.println(i);
    digitalWrite(D4, LOW);
/*CAYENNE_IN(0){
  // read the input on analog pin 0:
  int sensorValue = analogRead(D5);
  // print out the value you read:
  Serial.println(sensorValue);
if you have followed the steps from the link there should not be an issue. Are you getting any issue in the serial monitor. Use a plain code without the sensor and first connect your device to cayenne. then add the remaining code.
The serial monitor is working fine and the device is communicating with the Cayenne platform. I just cannot get it to work with the three relays, one is for a fan, the other is for air-conditioning and the last one is for the heat. The last part of the code is what I am trying to get to work.
you are using channel 0 for sending data and also for receiving data. You need to change either one to another number and have a button on cayenne dashboard with same channel number. And also you are sending data continuously in the void loop(). this will cause to hit rate limit. Have a look at this and make changes accordingly Sending MQTT messages within rate limits
Thanks, I am working on it and will be in touch.
