I2c LCD does not work
I have connected to Cayenne using usb serial connection. In my project I also need to display some measurements on LCD. I am suing I2C type of LCD. The problem is when I use the command cayenne.begin(), the lcd does not work.
Any suggestion please. Thanks
Sorry for the delay…Can you share your code?
Dear Adam
Sorry for late reply. The LCD work if I comment out the following statements:
In this project, I have two load cells that measure the weight of grocery items and displays the value on the cayenne dashboard and LCD. The cayenne dashboard is working but only the LCD giving me problem.
Hope to hear from you soon.
Umakandan
The code is as below:
#include <HX711.h>
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#define DOUT2 5
#define CLK2 4
#define DOUT 3
#define CLK 2
int allGood=10;
int alert=11;
HX711 scale(DOUT, CLK);
HX711 scale2(DOUT2, CLK2);
char username[] = "";
char password[] = "";
char clientID[] = "";
//Change this calibration factor as per your load cell once it is found you many need to vary it in thousands
float calibration_factor = -92050;//-106600 worked for my 40Kg max scale setup
float calibration_factor2 = -91850;
float weight1;
float weight2;
LiquidCrystal_I2C  lcd(0x27, 2, 1, 0, 4, 5, 6, 7);
//                         SETUP
//Cayenne.begin(username, password, clientID);
pinMode(12,OUTPUT);
pinMode(allGood,OUTPUT);
pinMode(alert, OUTPUT);
scale.set_scale(-92050);//Calibration Factor obtained from first sketch
scale2.set_scale(-91850);
scale.tare();             //Reset the scale to 0
scale2.tare();
lcd.begin(20, 4); // for 16 x 2 LCD module
lcd.setBacklightPin(3, POSITIVE);
lcd.setBacklight(HIGH);
lcd.home(); // set cursor to 0,0
lcd.print(" Welcome To ");
lcd.setCursor(0, 1);        // go to start of 2nd line
lcd.print("Grocery Notifier");
//                         LOOP
weight1 = scale.get_units();
weight2 = scale2.get_units();
if ( (weight1 < 0.4 && weight1 > 0.05 )||(weight2 < 0.4 && weight2 > 0.05 ))
digitalWrite(alert, HIGH);
else
digitalWrite(alert,LOW);
if( weight1 >= 0.4 && weight2>= 0.4)
digitalWrite(allGood,HIGH);
else
digitalWrite(allGood,LOW);
lcd.setCursor(0, 2);
lcd.print("Tray 1 = ");
lcd.setCursor(9, 2);
lcd.print(scale.get_units());
lcd.setCursor(14, 2);
lcd.print("kg");
lcd.setCursor(0, 3);
lcd.print("Tray 2 = ");
lcd.setCursor(9, 3);
lcd.print(scale2.get_units());
lcd.setCursor(14, 3);
lcd.print("kg");
// Cayenne.loop();
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(1,weight1);
Cayenne.virtualWrite(2, weight2);
Cayenne.virtualWrite(5,HIGH);
Cayenne.virtualWrite(10,HIGH);
else
Cayenne.virtualWrite(5,LOW);
Cayenne.virtualWrite(10,LOW);
CAYENNE_IN_DEFAULT()
CAYENNE_IN(3)
digitalWrite(12,getValue.asInt());
this is because cayenne.begin() waits until you are connected to cayenne and does not proceeds with further code. you may have problem with connecting to cayenne.
Thank you so much.
