I am making aquarium automation project.
Since triggers is not I decided to write if else for my project but it is not working the relay not turning on if condition is satisfied, if I try to get it on through Cayenne dashboard it get off instantly but same code working if I write if else in offline mode I mean only if else for realy ,plzz tell me where I get wrong.here I code
#include <NewPing.h>
//#define CAYENNE_DEBUG
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
// Set ESP8266 Serial object. In this example we use the Serial hardware serial which is available on boards like the Arduino Mega.
#define EspSerial Serial
int sensor =A0;
int sens = analogRead(sensor);
#define VIRTUAL_CHANNEL 10
ESP8266 wifi(&EspSerial);
#define VIRTUAL_CHANNEL 2
#define VIRTUAL_CHANNEL 3
#define VIRTUAL_CHANNEL 4
#define VIRTUAL_CHANNEL 6
#define TRIGGER_PIN 11 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 12 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200// Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
#define VIRTUAL_CHANNEL 7
#define VIRTUAL_CHANNEL 8
#define ACTUATOR_PIN 3
int ledpin=7;
int ledpina=8;
int ledpinb=9;
int feedbutton;
int filterbutton;
int motor1;
int motor2;
unsigned int uS;
CAYENNE_IN(2)
{ feedbutton = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
digitalWrite(7, getValue.asInt());
CAYENNE_IN(3)
{ filterbutton = getValue.asInt();
digitalWrite(3, getValue.asInt());
CAYENNE_IN(4){ motor1 = getValue.asInt();
digitalWrite(4, getValue.asInt());
CAYENNE_IN(5){ motor2 = getValue.asInt();
digitalWrite(5, getValue.asInt());
CAYENNE_OUT(8)
Serial.println("value ");
Serial.println(sens);
Cayenne.virtualWrite(8,sens);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
if(sens>650)// I am talking about this if else
digitalWrite(4,HIGH);
else
digitalWrite(4,LOW);
CAYENNE_OUT(6)
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
Serial.println("cm");
Cayenne.virtualWrite(6,uS / US_ROUNDTRIP_CM);
CAYENNE_IN(7)
if (getValue.asInt() == 0) {
digitalWrite(3, HIGH);
else {
digitalWrite(3, LOW);
//Cayenne.luxWrite(2, 700);
// Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
