Incorrect Alert Message
Hi Guys,
I have a bit of a bug with my message alerts,
I currently have a thermometer in a cool room its working fine readying between 1-3 degrees Celsius.
I have set up an alert to notify me if my temp goes above 4.5 deg c. This has worked for me in the past however now i am recieving a message every 10 seconds stating my system is over the threshold but when i log in its still sitting at approx 1deg c which is under the threshold?
ADDED: I have just noticed in between the refreshes (every 5 seconds or so) my temp shoots up to 83.00 deg c this is probably what is causing this any ideas?
Hey Mitch,
Hmm, which temp. sensor are you using?
