Irrigation cycle by pressing a button
who knows how to automate by pressing a button the irrigation system?
example: pressing X relay button 1 step 10sec - realy 2- etc …
Arduino is going to be your best bet. Code for when digital/virtual (digital write high) pin high, then do action on digital pin for so many milli seconds then “digital write low”
@Massimotruglio83
Connect your irrigation system to a relay and connect relay to GPIO4 of esp8266 board.
fill all the details in the code below and upload it into the esp8266.
on cayenne dashboard add a custom button widget with channel 1 selected.
//#define CAYENNE_DEBUG
int x;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = ";
char password[] = "";
char clientID[] ="";
unsigned long lastMillis = 0;
  pinMode(4, OUTPUT);
CAYENNE_IN(1)
  if (currentValue == 1)
    digitalWrite(4, HIGH);
  else
    digitalWrite(4, LOW);
i dint get what you are trying to do. can you give more detail about this.
I believe he wants to get a button he can press that will activate for a time then reset automatically.
Here is a post that has some code to do just that.
here it is. pressing a button I would like to be able to choose the irrigation time and then automatically switch off. so x 8 irrigation zones. would it be feasible?
@Massimotruglio83 for this you can add a slider and depending on the value of slider position you can set the time on for irrigation.
example. when slider is at 2, turn on the irrigation for 2 minutes.
please code :stuck_out_tongue:
the entire code :thinking:
first you give it a try
I guess at least hno excuse to leave … try it with yun but it hangs … while with arduin one seems to go
can you post the code and error. then i can help you.
#include <avr/io.h>
#include <avr/wdt.h>
#define Reset_AVR() wdt_enable(WDTO_30MS); while(1) {}
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22
#include <CayenneYun.h>
DHT dht(2,DHT22);
char token[] = "+++++++++";
int cicloirri=0;
float tempoirri=0;
float h =0;
float t=0;
unsigned long STARTINGTIME; //GESTIONE TIMER
  dht.begin();
  Cayenne.begin(token);
  //delay(1000);
  delay(1000);
  // Cayenne.virtualWrite(V2,cicloirri);
  h = dht.readHumidity(); // Leggo il valore di umidità
  t = dht.readTemperature(); // Leggo il valore di temperatura delay (1000);
    Serial.print("Umidità: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperatura: ");
    Serial.print(t);
    Serial.println(" *C");
    if (cicloirri==1)
       {Cicloirri();
CAYENNE_OUT(V0)
    Cayenne.virtualWrite(0, h);
    Serial.println("inviato dati!");
CAYENNE_OUT(V1)
    Cayenne.virtualWrite(1, t);
    Serial.println("inviato dati!!");
void Cicloirri()
    Serial.println("inizio ciclo irri");
    digitalWrite(3,LOW);
    delay(tempoirri);
    Serial.println("chiudo 1 apro 2");
    digitalWrite(3,HIGH);
    digitalWrite(4,LOW);
    delay(tempoirri);
    Serial.println("chiudo 2 apro 3");
    digitalWrite(4,HIGH);
    digitalWrite(5,LOW);
    delay(tempoirri);
    digitalWrite(5,HIGH);
    Serial.println("fine ciclo");
  cicloirri=0;
   delay(1000);
  Cayenne.syncAll();
  CAYENNE_IN(V2)
{ Cayenne.syncAll();
  CAYENNE_LOG("Got a value: %s", getValue.asStr());
  // You can also use:
  cicloirri = getValue.asInt() ;
  // double d = getValue.asDouble()
 CAYENNE_IN(V3)
  tempoirri = getValue.asInt() ;
  Serial.println(tempoirri);
CAYENNE_DISCONNECTED() {
Reset_AVR();
can you post the error and give a bit detail about your code.
not by mistake, but but crashes arduino and does not do the correct cycle
#14
I looked over the code quick and didn’t notice anything that stood out. As @shramiksalgaonkar said, what error are you getting?
#15
it does not do its job, it crashes it disconnects and starts again …
#16
There must be some error though, right? Is it a WDT reset?
#17
Why do you need this, esp keeps connection up and reset its self if no conection.
Regarding your question, if you want your relays to activate at certain time, use schedule.
If you want to have it on demand using button press then better solution is to use hardware solution and timers/milis other than cloud system, then after that you can add Cayenne actuator for remote controle of that hardware button.
Its more reliable solution
