- Device & model you are using Arduino Uno with W5100 ethernet shield
Web, iOS, Android)
Arduino: 1.6.12 (Windows 7), Board: “Arduino/Genuino Uno”
Sketch uses 18,142 bytes (56%) of program storage space. Maximum is 32,256 bytes.
Global variables use 665 bytes (32%) of dynamic memory, leaving 1,383 bytes for local variables. Maximum is 2,048 bytes.
Error opening serial port ‘COM17’. (Port busy)
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6f
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
im trying to connect my arduino uno with ethernet. but when uploading that,it connect connect.
what should i do?
