Just loaded jessie onto my orange pi and updated then attempted to install mydevices and I get error: certificate of “update.mydevices.com” is not trusted/ error: certificate of “update.mydevice.com” has no known issuer.
I don’t have an Orange Pi, so just purely taking a guess here, but even if you solve that problem I think you will run in to errors as the drivers will not work correctly. I think what I would do is go the MQTT route. That’s how I ended up getting my Tinker Board connected.
I think as @adam said, MQTT would be the best option here. Adam you think your mqtt RPi post is a good tutorial for @wmontg5988 to follow for MQTT on the Orange Pi? DHT11/DHT22 with Raspberry Pi
I did want to add that while I agree MQTT is the best solution here, for this specific install issue, it can be worked around with the steps in this post: Installing Cayenne - #7 by rsiegel
It seems to occur now and then on even Raspberry Pi devices, and I suspect a configuration issue on the device side rather than any issue with the certificate on our server – but the check can be ignored using those steps.
Looks like after trying from the post you mention(it did some crazy stuff) that MQTT will be the next solution. I really want to achieve this so time to study up!
