LinkNode D1 Setup
I am trying to setup another LinkNode D1 but am unable to find where the authorization token is hiding on my dashboard when I attempt to add a new microcontroller.
This is the code I am using with my existing, working controller:
#include "CayenneDefines.h"
#define R1 D5
#define R2 D2
char ssid[] = "xxx";
char password[] = "xxx";
char token[] = "xxxxxxxxxx";
  pinMode(R1, OUTPUT);
  pinMode(R2, OUTPUT);
  digitalWrite(R1, HIGH);
  digitalWrite(R2, HIGH);
CAYENNE_IN(V1)
  CAYENNE_LOG("Got a value: %s", getValue.asStr());
  int i = getValue.asInt();
  if (i == 0)
  else
    digitalWrite(R1, LOW);
CAYENNE_IN(V2)
  if (i == 0)
  else
    digitalWrite(R2, LOW);
you are using old cayenne library. Follow this tutorial Adding a New Device using MQTT
