Looking for a simple MQTT example with Multiple relays/lights
So I am trying to hook up an Arduino with a 4 relay board
I can (almost) copy and past the example for a single relay…
but it seems that something is missing for adding more than 1
any chance of getting a sample for 2-4 relays?
have a look at this Adding a New Device using MQTT and understand how it works. then you can do anything with cayenne,
yea… I’ve tried to read all that… too much info in a somewhat confusing and over whelming format…
while I wish I had the time to sort thru it and be able to do “anything with cayenne” right now what I need is to be able to do one thing, because this is just a small part of a much larger project…
if someone would take this: https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Actuators/RelaySwitch/RelaySwitch.ino
and throw in for a second relay… I’d understand enough to put in 2 more and be able to turn the lights back on in my garage… they were hooked to a RPi and Cayenne but the RPI died… and I’m trying to clean up the garage
i hope the below code is not confusing and over whelming .
#define VIRTUAL_CHANNEL1 1
#define ACTUATOR_PIN1 4
#define VIRTUAL_CHANNEL2 2
#define ACTUATOR_PIN2 5
#define VIRTUAL_CHANNEL3 3
#define ACTUATOR_PIN3 6
#define VIRTUAL_CHANNEL4 4
#define ACTUATOR_PIN4 7
  pinMode(ACTUATOR_PIN1, OUTPUT);
  pinMode(ACTUATOR_PIN2, OUTPUT);
    pinMode(ACTUATOR_PIN3, OUTPUT);
  pinMode(ACTUATOR_PIN4, OUTPUT);
CAYENNE_IN(VIRTUAL_CHANNEL1)
	if (getValue.asInt() == 0) {
		digitalWrite(ACTUATOR_PIN1, HIGH);
	else {
		digitalWrite(ACTUATOR_PIN1, LOW);
CAYENNE_IN(VIRTUAL_CHANNEL2)
		digitalWrite(ACTUATOR_PIN2, HIGH);
	else {
		digitalWrite(ACTUATOR_PIN2, LOW);
}CAYENNE_IN(VIRTUAL_CHANNEL3)
		digitalWrite(ACTUATOR_PIN3, HIGH);
	else {
		digitalWrite(ACTUATOR_PIN3, LOW);
CAYENNE_IN(VIRTUAL_CHANNEL4)
		digitalWrite(ACTUATOR_PIN4, HIGH);
	else {
		digitalWrite(ACTUATOR_PIN4, LOW);
Thank you very much… I will be re-reading (and probably re-re-re-reading ) the article later.
but as I said earlier… way too much on my plate right now…
the example I pointed to was just a hair away from being enough info… what you posted makes sense and about what I expected…
once again, thanks…
