Many Channels / Widgets Not initiating Correctly inc Graphs
Using Wemos D1 MQTT, on both the Web (firefox) and android app.
I have many issues that I feel may all be linked to this. Surely this is a bug, it is sooo frustrating that there is not more information available, I have been using Cayenne for around 6 months I had similar issues when I first used Cayenne, and again recently in the past few weeks (Since Arduino updated to MQTT), here is what I have found so far:
Many times you add a new channel to dashboard directly from what is auto detected by cayenne, at this point often you do not get the option to choose any other widget than value widget, at this point you might as well quit and start again - I read somewhere you should always use the first cayenne channel initiated widget to create the graph, then create any other widgets manually, however as option often doesn’t present itself…this is not possible.
This has happened on data types ‘Analog’, ‘Temperature’ and ‘Humidity, maybe more but for me this is what I have experienced.
I have also noticed that when setting data type at arduino to analog and then selecting this as data type on cayenne widget the widget disappears!
Many times when you delete widgets, they remain in the left Navigation tree for the device - impossible to delete!
I also have some widgets that display graphs but the timescales are wrong (Stuck at period in the past) the ‘no data for this period’ seems to be related to the graph updating its current date as the dates displayed are always wrong - it isnt that it can’t display for [This period] it is that it can’t display for some other distant past period.
Some widget also will not allow you to get historical data from the chart pop up either (I assume similar issue)
I have done F5 etc so not an issue with cache etc.
Because I can only get part of maybe 30 widgets working I have not reset up any of my triggers and reluctant to do so at this point. I wanted to expand this out but it is just so frustrating, I have added and then deleted maybe 200 widgets 
Argh…
HI @paulminize,
Think you can post your code?
~Benny
Code below, very new to coding/arduino so have to excuse its ugliness :wink:
#include <WEMOS_SHT3X.h>
char ssid = “XXXX”;
char wifiPassword = “XXXX”;
// char token = “XXXX”;
char username = “XXXX”;
char password = “XXXX”;
char clientID = “XXXX”; // Zone 1 - XXXX Zone 2 - XXXX
unsigned long lastMillis = 0;
SHT3X sht30(0x45);
pinMode(D3, INPUT_PULLUP); //Fire
pinMode(A0, INPUT); //Light
sht30.get();
   Serial.println(sht30.cTemp);
   Serial.println(sht30.humidity);
int sensorValue2 = digitalRead(D3);
int sensorValue3 = analogRead(A0);
Serial.print("Sensor 2: "); Serial.println(sensorValue2);
Serial.print("Sensor 3: "); Serial.println(sensorValue3);
if ((sensorValue2) == 0) {
Cayenne.virtualWrite(3, 1, “digital_sensor”, “d”);
Serial.println(“System Alert: - Fire Status: FIRE DETECTED”);
Serial.println(“System Action: - Shutting Down All Electrical Outputs / Sprinkler System Activating”);
else {
Serial.println(“System Status: - No Faults Detected”);
Cayenne.virtualWrite(3, 0, “digital_sensor”, “d”);
if ((sensorValue3) < 700) {
Serial.println(“System Status: - Lights Are Currently On”);
Cayenne.virtualWrite(5, 1, “digital_sensor”, “d”);
else {
Serial.println(“System Status: - Lights Are Currently Off”);
Cayenne.virtualWrite(5, 0, “digital_sensor”, “d”);
//Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
lastMillis = millis();
Cayenne.virtualWrite(0, lastMillis / 60000);
Cayenne.virtualWrite(1, sht30.cTemp, “temp”, “c”);
Cayenne.virtualWrite(2, sht30.humidity, “rel_hum”, “p”);
Cayenne.virtualWrite(4, 1023 - (sensorValue3));
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Partly solved some issues / workaround
Although still have many widgets that cannot be changed to other types, and even when deleting them, the new replacement suggested by dashboard still cannot be changed - examples -
Zone 2 RCU -
Reservoir Temp Chart can not be changed to any other type of widget.
Channel 1 (Not configured yet) if you try to add - will not allow change of widget.
Cheers
I have changed code, just noticed some values were being sent outside the timer, so moved them.
Also changed timer to 10secs not 1sec.
Hey slowly improving code at my end, I seem to have everything working as it should do at the minute, although noticed my account password didn’t change again, I received the email and attempted to change it twice, sure I got success messages on both occasions too? Maybe just me?
Cheers
