Mega Compilation Error
Struggling to get the compile to work. Pretty sure the hardware is okay as the Token Authentication works via Code found in Cayenne Examples. However the code that is provided from the website pasted below always results in an error. The additional #includes Ethernet/SPI were added by me but it makes no difference. I am running a mega 2560 with w5100 ethernet. Any suggestions are greatly appreciated.
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#include <Ethernet.h>
#include <SPI.h>
char username[] = "";
char password[] = "";
char clientID[] = "";
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
@Chambers3000
remove #include <Ethernet.h> and remove uncomment // before one of the
I couldn’t get board to connect un’til data was sent.
Hope this helps
Thank you sir!
