Merge sketch to cayenne
Hi everyone, I was successful read with two sensor, they are voltage sensor and current sensor. And I feel dificult to merge with cayenne. Could you help me to merge these 3 sketch please?
//#define CAYENNE_DEBUG
#define led_1_pin 2
#define led_2_pin 3
#define led_3_pin 4
#define led_4_pin 5
#define led_5_pin 6
#define led_6_pin 7
#define led_7_pin 8
char username = “…”;
char password = “…”;
char clientID = “…”;
unsigned long lastMillis = 0;
pinMode(led_1_pin, OUTPUT);
pinMode(led_2_pin, OUTPUT);
pinMode(led_3_pin, OUTPUT);
pinMode(led_4_pin, OUTPUT);
pinMode(led_5_pin, OUTPUT);
pinMode(led_6_pin, OUTPUT);
//Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
lastMillis = millis();
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(1) // Get current value of led 1 button
int x = getValue.asInt();
digitalWrite(led_1_pin, x);
CAYENNE_IN(2) // Get current value of led 2 button
int x1 = getValue.asInt();
digitalWrite(led_2_pin, x1);
CAYENNE_IN(3) // Get current value of led 3 button
int x2 = getValue.asInt();
digitalWrite(led_3_pin, x2);
CAYENNE_IN(4) // Get current value of led 4 button
int x3 = getValue.asInt();
digitalWrite(led_4_pin, x3);
CAYENNE_IN(5) // Get current value of led 5 button
int x4 = getValue.asInt();
digitalWrite(led_5_pin, x4);
CAYENNE_IN(6) // Get current value of led 6 button
int x5 = getValue.asInt();
digitalWrite(led_6_pin, x5);
pinMode (A0, INPUT);
unsigned int c = 0.0;
float nilaiACS =0.0, sampling=0.0, rate=0.0, fnilaiACS=0.0;
for (int i =0; i<150; i++){
nilaiACS = analogRead(A0);
sampling = sampling + nilaiACS;
delay(10);
rate = sampling/150.0;
fnilaiACS = (2.71 - (rate*(4.7 / 1024.0)) / 0.185);
if (fnilaiACS < 0.01)
fnilaiACS = 0.0;
Serial.print(fnilaiACS);
Serial.println (" Ampere");
delay(100);
DC Voltmeter Using a Voltage Divider
Based on Code Created By
T.K.Hareendran
int analogInput = A1;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.0; //
float R2 = 7500.0; //
int value = 0;
pinMode(analogInput, INPUT);
Serial.print(“DC VOLTMETER”);
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 5.0) / 1024.0; // see text
vin = vout / (R2 / (R1 + R2));
if (vin < 0.1)
vin = 0.0;
Serial.print("INPUT V= ");
Serial.println(vin, 2);
delay(500);
i am guessing you want to show current and voltage value on cayenne dashboard.
use Cayenne.virtualWrite(1, fnilaiACS, "current", "a"); for current value widget.
and Cayenne.virtualWrite(1, vin , "voltage", "v"); for voltage value widget.
Thanks a lot, its work.
glad to hear that. can you share the code if possible.
Here we go,
// #define CAYENNE_DEBUG
#define led_1_pin 2
#define led_2_pin 3
#define led_3_pin 4
#define led_4_pin 5
#define led_5_pin 6
#define led_6_pin 7
#define led_7_pin 8
#define analogInput0 0
#define analogInput1 1
// Volmeter
float vout = 0.0;
float vin = 0.0;
int value = 0;
char username[] = ".....";
char password[] = ".....";
char clientID[] = ".......";
  Serial.print("DC VOLTMETER");
  pinMode(analogInput0, INPUT);
  pinMode(analogInput1, INPUT);
  // ACS712-30A
  delay(10);
fnilaiACS = (2.71 - (rate*(5.0 / 1024.0)) / 0.185);
  if (fnilaiACS < 0.05)
    fnilaiACS = 0.0;
    Cayenne.virtualWrite(0, fnilaiACS, "current", "a");
      //Voltmeter
  if (vin < 0.50)
    vin = 0.0;
  nilaiACS = analogRead(analogInput0);
  delay(10);
fnilaiACS = (5.0 - (rate*(5.0 / 1024.0)) / 0.9);
    fnilaiACS = 0.0;
thank you @asmararahardian . it will great if you can submit your project for the community to have a look. Projects Made with Cayenne - myDevices Cayenne Community
