Methods Cayenne LPP
I want creat a simple channel, like this image:
but has just this methods, and I can’t creat a simple channel,
below are the methods for I put in ESP32.
uint8_t addDigitalInput(uint8_t channel, uint8_t value);
uint8_t addDigitalOutput(uint8_t channel, uint8_t value);
uint8_t addAnalogInput(uint8_t channel, float value);
uint8_t addAnalogOutput(uint8_t channel, float value);
uint8_t addLuminosity(uint8_t channel, uint16_t lux);
uint8_t addPresence(uint8_t channel, uint8_t value);
uint8_t addTemperature(uint8_t channel, float celsius);
uint8_t addRelativeHumidity(uint8_t channel, float rh);
uint8_t addAccelerometer(uint8_t channel, float x, float y, float z);
uint8_t addBarometricPressure(uint8_t channel, float hpa);
uint8_t addGyrometer(uint8_t channel, float x, float y, float z);
uint8_t addGPS(uint8_t channel, float latitude, float longitude, float meters);
Can you post the code you are using?
This library Cayenne LPP arduino-device-lib/src at master · TheThingsNetwork/arduino-device-lib · GitHub
#include <CayenneLPP.h>
#include <DHTesp.h>
#include "DHT.h"
#include <Adafruit_GPS.h>
#include <HardwareSerial.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <Wire.h>
#include <math.h>
#include "SSD1306.h"
static const PROGMEM u1_t NWKSKEY[16] ={ 0x58, 0x47, 0xC1, 0xC3, 0xD3, 0x74, 0x4C, 0xF8, 0xEC, 0x53, 0xCE, 0xDA, 0xEE, 0xA1, 0x7D, 0x3D };
static const u1_t PROGMEM APPSKEY[16] = { 0x1A, 0x04, 0xD2, 0x56, 0xCC, 0xA2, 0xF4, 0x3C, 0xE9, 0x35, 0x7A, 0xE6, 0x2B, 0x6E, 0xF7, 0x7B };
static const u4_t DEVADDR = { 0x260311A9 };
void os_getArtEui (u1_t* buf) { }
void os_getDevEui (u1_t* buf) { }
void os_getDevKey (u1_t* buf) { }
static osjob_t sendjob;
const unsigned TX_INTERVAL = 10;
const lmic_pinmap lmic_pins = {
  .nss = 18,
  .rxtx = LMIC_UNUSED_PIN,
  .rst = 14,
  .dio = {26, 33, 32},
int dhtPin = 17;
const int pinSensorPIR = 34;
int valorSensorPIR = 0;
int valorDC = 35;
float tensaoDC;
float t=0;
float h=0;
float f=0;
#define DHTTYPE DHT22
// Adafruit GPS
#define SERIAL1_RXPIN 12
#define SERIAL1_TXPIN 13
HardwareSerial gpsSerial(2);
CayenneLPP lpp(15);
SSD1306 display(0x3c, 4, 15); //construtor do objeto que controlaremos o display
DHT dht(dhtPin, DHTTYPE);
void onEvent (ev_t ev)
  Serial.print(os_getTime());
  Serial.print(": ");
  switch(ev)
    case EV_TXCOMPLETE:
      Serial.printf("EV_TXCOMPLETE (includes waiting for RX windows)\r\n");
      os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
      break;
    case EV_RXCOMPLETE:
      if (LMIC.dataLen)
        Serial.printf("Received %d bytes\n", LMIC.dataLen);
      break;
    default:
      Serial.printf("Unknown event\r\n");
      break;
void do_send(osjob_t* j)
  if (LMIC.opmode & OP_TXRXPEND)
    Serial.printf("OP_TXRXPEND, not sending\r\n");
  else
  if (!(LMIC.opmode & OP_TXRXPEND))
    lpp.reset();
    float valorTeste = 39;
    lpp.addTemperature(1, t);
    lpp.addRelativeHumidity(2, h);
    //lpp.addRelativeHumidity(3, valorTeste);
    Serial.printf("Temperature : %.2f, Humidity : %.2f\r\n", t, h);
    display.clear();
    display.drawString(0, 0, "Temperature: ");
    display.drawString(90, 0, String(t));
    display.drawString(0, 20, "Humidity  : ");
    display.drawString(90,20, String(h));
    display.display();
    LMIC_setTxData2(1, lpp.getBuffer(), lpp.getSize(), 0);
    Serial.printf("Packet queued\r\n");
  Serial.begin(115200);
  Serial.printf("Starting...\r\n");
  pinMode(16,OUTPUT);
  digitalWrite(16, LOW); // set GPIO16 low to reset OLED
  delay(50);
  digitalWrite(16, HIGH);
  display.init();
  display.setFont(ArialMT_Plain_10);
  dht.begin();
  os_init();
  LMIC_reset();
  uint8_t appskey[sizeof(APPSKEY)];
  uint8_t nwkskey[sizeof(NWKSKEY)];
  memcpy_P(appskey, APPSKEY, sizeof(APPSKEY));
  memcpy_P(nwkskey, NWKSKEY, sizeof(NWKSKEY));
  LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
  LMIC_setLinkCheckMode(0);
  LMIC.dn2Dr = DR_SF7;
  LMIC_setDrTxpow(DR_SF7,14);
  Serial.printf("LMIC setup done!\r\n");
  do_send(&sendjob);
   PegarTemperatura();
  os_runloop_once();
void PegarTemperatura(){
valorSensorPIR = digitalRead(pinSensorPIR);
  tensaoDC = ((valorDC*0.00450)*5);
   h = dht.readHumidity();
   t = dht.readTemperature();
  f = dht.readTemperature(true);
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  float hif = dht.computeHeatIndex(f, h);
  float hic = dht.computeHeatIndex(t, h, false);
  delay(2000);
what is the problem you are facing?
I’m kind of confused. LPP is for LORA devices but you mention an ESP32. Can you give us a better idea of what you are trying to do?
I want create a simple channel, not a specific channel like this:
if I pack any of these they come with certain properties on the Cayenne, in which sometimes I do not want to use, I don’t know if you me understand. For example, I want just a value (500 lbs) in the Cayenne, lbs no has in methods, so, I need just a show this value.
uint8_t addlbs(uint8_t channel, uint8_t value); - no has lbs (example).
You can check our LPP format doc
Unfortunately it only supports data types and units mentioned in it
