Missing save button when changing temp sensor settings on Android pixel 2 xl
Whenever I try and change a sensor or add new I can’t save the change when on my Android device. I have a pi running raspbian 9 and all up to date.
Am I doing something wrong?
you need to select a channel, then save option will appear on right top corner.
That was why I wasn’t seeing the save, thank you very much!
I still select a channel and it sometimes disappears after a few minutes when I go back in there. Is there a way I know what channel to select? Temperature even reverts back to C from F sometimes. Kinda weird…
Thank you
yes, we have noticed this bug and will let you know once solved.
