Monitoring and alerting system + Cayenne
About This Project
A simple project for monitoring temperature and pressure using BMP180 and an LED to tell me that if the pressure is below or above a certain value.
I am sensitive to pressure changes and it gives me the heads up
What’s Connected
Raspberry Pi 2 + BMP180 + Green LED
Triggers & Alerts
Two triggers are used: one to shut the LED off when Pressure is below 997 hPa and one to shut it on when above
Scheduling
No scheduling
Dashboard Screenshots
Photos of the Project
One thing I noted when working on this project is that the BMP180 device in the GUI is broken. When you select unit (Pa or hPa) then the pressure indicator stops working all together.
Cool simple project :slight_smile: Thanks so much for sharing!
Yes, that is a bug that we will be fixing. @rsiegel adding you here to make you aware.
