Motion Sensor with Arduino MQTT
Has anyone managed to get the motion sensor working on an Arduino with the new MQTT?
I am wondering if it is my code.
Yes, you just need a generic digital input widget. Can you post your code?
Adam,
Thank you for the prompt reply. I did get it to work but it is still a bit slow. Currently I have triggers set to turn on and off the white light with motion. This is a huge step since the MQTT upgrade of the system. I just wish the response times were a bit faster.
WW
Steps:
1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
2. Compile and upload the sketch.
3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#include <OneWire.h>
char username[] = "xxxnotsharingthisxxx";
char password[] = "xxxnotsharingthisxxx";
char clientID[] = "xxxnotsharingthisxxx";
#define LUXSENSOR_PIN 0
#define TEMPSENSOR_PIN 7
#define MOTIONSENSOR_PIN 2
#define WHITELIGHT_PIN 3
#define GREENLIGHT_PIN 6
#define YELLOWLIGHT_PIN 5
#define REDLIGHT_PIN 4
#define VIRTUAL_CHANNEL1 1
#define VIRTUAL_CHANNEL2 2
#define VIRTUAL_CHANNEL3 3
#define VIRTUAL_CHANNEL4 4
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 6
#define VIRTUAL_CHANNEL7 7
OneWire oneWire(TEMPSENSOR_PIN);
  sensors.begin();
  pinMode(WHITELIGHT_PIN, OUTPUT);
  pinMode(GREENLIGHT_PIN, OUTPUT);
  pinMode(YELLOWLIGHT_PIN, OUTPUT);
  pinMode(REDLIGHT_PIN, OUTPUT);
  checkSensor();
int previousState = -1;
int currentState = -1;
void checkSensor()
  if (currentMillis - previousMillis >= 2000) {
    currentState = digitalRead(MOTIONSENSOR_PIN);
      Serial.println("Sending data to Cayenne");
      Cayenne.virtualWrite(VIRTUAL_CHANNEL3, currentState, "digital_sensor", "d");
      previousState = currentState;
CAYENNE_OUT(VIRTUAL_CHANNEL1)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(LUXSENSOR_PIN));
CAYENNE_OUT(VIRTUAL_CHANNEL2)
  // Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL2, sensors.getTempFByIndex(0));
CAYENNE_IN(VIRTUAL_CHANNEL4)
  int value = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL4, WHITELIGHT_PIN, value);
  digitalWrite(WHITELIGHT_PIN, value);
CAYENNE_IN(VIRTUAL_CHANNEL5)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL5, GREENLIGHT_PIN, value);
  digitalWrite(GREENLIGHT_PIN, value);
CAYENNE_IN(VIRTUAL_CHANNEL6)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL6, YELLOWLIGHT_PIN, value);
  digitalWrite(YELLOWLIGHT_PIN, value);
CAYENNE_IN(VIRTUAL_CHANNEL7)
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL7, REDLIGHT_PIN, value);
  digitalWrite(REDLIGHT_PIN, value);
the delay you get is because of this. change it to 250
Thank you for catching that. I think I changed that when trouble shooting the triggers.
