MQTT Arduino UNO with ESP8266 as shield
Could somebdy review my code? I just conect my arduino to MQTT but temporary widgets not appear and if I add by custom widgets data is empty.
What I am doing wrong?
I can see comunicatin by serial.
Here my code
#include “DHT.h”
char ssid[] = “xequebo”;
char wifiPassword[] = “++++”;
char username[] = “8****++1”;
char password[] = “******+”;
char clientID[] = “98090b10-14d1-11e8-aa1d-++++++”;
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
#define DHTPIN 7
#define DHTTYPE DHT11 // DHT 11
#define SENSOR_PIN 1 // fotoresistor
#define Azul 9 //PWM LED
#define Rojo 10 //PWM LED
#define Verde 11 //PWM LED
#define Amarillo 12
#define Blanco 13
DHT dht(DHTPIN, DHTTYPE);
#define VIRTUAL_CHANNEL 1 // Temperatura
#define VIRTUAL_CHANNEL2 2// Humedad
#define VIRTUAL_CHANNEL3 3// Luminosidad
#define VIRTUAL_CHANNEL4 4// Led
#define VIRTUAL_CHANNEL5 5// Led
#define VIRTUAL_CHANNEL6 6// Led
#define VIRTUAL_CHANNEL7 7// Led
#define VIRTUAL_CHANNEL8 8// Led
dht.begin();
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(9600);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL,t,TYPE_TEMPERATURE,UNIT_CELSIUS);
CAYENNE_OUT(VIRTUAL_CHANNEL2)
float h = dht.readHumidity();
Cayenne.virtualWrite(VIRTUAL_CHANNEL2,h,TYPE_RELATIVE_HUMIDITY,UNIT_PERCENT);
CAYENNE_OUT(VIRTUAL_CHANNEL3)
Cayenne.virtualWrite(VIRTUAL_CHANNEL3, analogRead(SENSOR_PIN),TYPE_LUMINOSITY,UNIT_LUX);
CAYENNE_IN(VIRTUAL_CHANNEL4)
int value = getValue.asInt(); // 0 to 255
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL4, Azul, value);
// Write the value received to the PWM pin. analogWrite accepts a value from 0 to 255.
analogWrite(Azul, value);
CAYENNE_IN(VIRTUAL_CHANNEL5)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL5, Rojo, value);
analogWrite(Rojo, value);
CAYENNE_IN(VIRTUAL_CHANNEL6)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL6, Verde, value);
analogWrite(Verde, value);
CAYENNE_IN(VIRTUAL_CHANNEL7)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL7, Amarillo, value);
digitalWrite(Amarillo, value);
CAYENNE_IN(VIRTUAL_CHANNEL8)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL8, Blanco, value);
digitalWrite(Blanco, value);
If I monitor the serial port I can see comunication:
T+CIPSEND=1,40
[9903872] Publish: topic 1, channel 3, value 411, subkey lux, key lum
AT+CIPSEND=1,40
[9908895] Publish: topic 1, channel 0, value 9908895, subkey , key
AT+CIPSEND=1,40
[9913917] Connection ok
[9914233] Publish: topic 1, channel 1, value 26.000, subkey c, key temp
AT+CIPSEND=1,40
[9919531] Publish: topic 1, channel 2, value 53.000, subkey p, key rel_hum
AT+CIPSEND=1,40
[9924560] Publish: topic 1, channel 3, value 421, subkey lux, key lum
AT+CIPSEND=1,40
[9929584] Publish: topic 1, channel 0, value 9929584, subkey , key
AT+CIPSEND=1,40
But dashboard not works:
Advanced thanks fr yur support¡¡¡
first try this simple code and see if the board gets connected to cayenne and you see a value widget on the dashboard
unsigned long lastMillis = 0;
delay(10);
  if (millis() - lastMillis > 60000)
    lastMillis = millis();
Cayenne.virtualWrite(2, millis());
Thanks fr the suggestion, the widget still not appear even if I delete the device and try to add a new one, same behavior: device is detected but widget no appears…
Serial comunnications still send messages but nothing reflects on dashboard:
AT+CIPSEND=1,40
[93933] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
AT+CIPSEND=1,40
[98960] Publish: topic 7, channel 65534, value 16000000, subkey , key
AT+CIPSEND=1,40
1kav1/8ca111e0-e1f6-11e7-9768-2143f8645AT+CIPSEND=1,40
011/things/2ff16c80-159d-11e8-822e-bbf38AT+CIPSEND=1,29
[104699] Publish: topic 5, channel 65534, value 1.1.0, subkey , key
AT+CIPSEND=1,40
[109722] Publish: topic 8, channel 65534, value ESP8266, subkey , key
[109759] Connection ok
I think you have some minor mis types which is stopping the data from reaching Cayenne, even though the device connects.
Looks like you are trying to add DHT11 sensor, use this post as a guide to see how the text is formatted :slight_smile:
~Benny
Thanks for the info, in addition I guess that other mistakes are present.
due I’m using old comands like:
instead the new ones, rigth? as well the #define comands used wronly…
HEY¡¡
Now is starting to work, I re-plan and read carefully the docs and It succes¡¡:
This is the code That I use:
#include “DHT.h”
char wifiPassword[] = “0”;
char username[] = “0”;
char password[] = “0”;
char clientID[] = “0”;
#define DHTPIN 7
delay(10);
dht.begin();
delay(10);
Cayenne.luxWrite(2, analogRead(1));
Cayenne.virtualWrite(3, t, TYPE_TEMPERATURE, UNIT_CELSIUS);
Cayenne.virtualWrite(4, h, TYPE_RELATIVE_HUMIDITY, UNIT_PERCENT);
CAYENNE_IN_DEFAULT()
I will continious with actuators, But NOW I AM ON THE RIGTH WAY¡¡
