MQTT data slow
Cayenne MQTT data updates very slow. Using Mqtt for first time. The data changes only once in 10-15 seconds. The last data packet sent also changes every 10-15 seconds. Im using arduino and ESP8266 shield. even using example code the data changes slow
have a look at this Sending MQTT messages within rate limits
Ive used cayenne for major project. Before it was superfast. Now its lagging. Im in trouble. When will it end
so it is a way cayenne MQTT works.
what is your project?
iot based monitoring temp,presure and humidity
have a look at the library category, you will find MQTT based examples for your project.
Sure bro
