MQTT example give an error
When I try to compile the MQTT example: https://github.com/myDevicesIoT/cayenne-docs/blob/staging/examples/MQTT_EthernetShieldW5100_with_TMP36/MQTT_EthernetShieldW5100_with_TMP36.ino
The result is:
‘struct Request’ has no member named ‘pin’
can you use request.channel ?
