Hi
I tried your MQTT interface for my existing project and I have a few improvements that would be a great addition for ‘bring your own thing’:
-the command channel could use some additions to externally configure the dash board like:
-changing the name and/or channel name of a widget by MQTT command
-adding custom units (like ‘moisture’) to a value or a channel
-be able to supply or change the widget type of a channel by command
-upload a custom image for the device (instead of the cayenne icon)
-make it possible to create custom command buttons instead of only triggers so the user can configure the controlled ‘thing’ for example to change the update rate or offset values
