Multiple Tmp102?
Hi. Is it possible to use multiple tmp102 sensors using different addresses but the same wiring ? 4 addresses are available but can 4 sensors be used ? Tutorial only shows the default first address. Thanks - Neil
Yep, you can add up to 4. Just select the address in the drop down.
Also note that you’ll need to wire each one differently in order to assign each a different address.
Excellent! Thanks I was hoping that this was the case. Better get some more ordered then.
Great news ! Thanks for the quick response. I was hoping that it would be this simple.
Kate Moss, the international super model?! So honoured.
We’re not worthy. We’re not worthy. :blush:
:wink::+1:t2:
