Multiple TSL2561 Luminocity Sensors
I add an one TSL2561 and it is working. However when I try to add one more sensor, I can’t add i to the dashboard. I know that the default address of this sensor is 0x39. Does the second one has the same as the address is burned in hardware?
Can somebody give me more explanation and if there is anyway to wire more than one sensor?
Thank you in andvance :wink:
You can change the address of the sensor to 0x49 or 0x29 by connecting the ADDR pin to VCC or ground. There is a section on it in this article:
