hi
is it possible to have the choice in devices to have the infrared sensor mxl90614…
that would be great.
Hey that device looks cool…
May copy this to new ideas department…
I would like to see (in general) a Generic I2c input option on the add device menu. It would be not that much more complicated to:
Add Sensor > Generic > I2c and fill out the address and register(s) of interest into an xbit variable. This would save repeating set up of a lot of ‘one off’ gadgets. Your team your side would soon see ‘what was hot’ and copy and paste it as a common device into the drop down pathway for others to follow…
~ Andrew
I created this sample below for the Adafruit MLX90614 using Blynk and Particle integration. To use Cayenne I’m beginning to explore Node Red similar to the post here: Using Node-RED as a Local Fallback Server
#include <Adafruit_MLX90614.h>
mlx.readAmbientTempC()
mlx.readObjectTempC()
mlx.readAmbientTempF()
mlx.readObjectTempF()
#include <blynk.h>
char auth[] = "<Auth token from Blynk>";
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
delay(5000); // Allow board to settle
Blynk.begin(auth);
mlx.begin();
BLYNK_READ(V1){
int objtemp = mlx.readObjectTempF();
Blynk.virtualWrite(V1,objtemp);
delay(100);
BLYNK_READ(V2){
int ambtemp = mlx.readAmbientTempF();
Blynk.virtualWrite(V2,ambtemp);
delay(100);
Blynk.run();
Hope it helps.
Showing some love to Cayenne below after redoing the project. Along with some widgets I was able to map the Adafruit MLX90614 readouts to the virtual pins.
#include "cayenne-particle.h"
/*mlx.readAmbientTempC()
mlx.readObjectTempF()*/
char auth[] = "<Auth Code>";
Blynk.begin(auth);
mlx.begin();
BLYNK_READ(V1){
delay(100);
BLYNK_READ(V2){
delay(100);
Blynk.run();
Cool stuff, thanks for sharing your code…it helps when other users are searching for the code for that specific sensor.
If you had a project you built, we’d love to see it posted in our ‘Projects Made with Cayenne’ category.
-Benny
