I am Bernard from France … I am fan of IOT and Cayenne.
First of all I would like apologize for my broken English.
This is my first project and I must say I used copy and paste but I thing I have learnt a lot.
// ESP8266 --> SCL pin = d1 SDA = d2
// BUILT_IN led ligth when LOW (inversée)
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <Adafruit_ADS1015.h>
#include "DHT.h"
char ssid[] = "";
char wifiPassword[] = "";
// Cayenne authentication info.
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
#define DHTPIN D4
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
Adafruit_ADS1115 adc(0x48);
float hum, temp, f;
byte restartMcu = 0;
bool online = false;
adc.begin();
pinMode(D5, OUTPUT); // relay#1
pinMode(D7, OUTPUT); // relay#2
pinMode(D3, OUTPUT);
digitalWrite(D7, LOW);
pinMode(D0, OUTPUT);
digitalWrite(D0, HIGH);
float Voltage;
long wifiRSSI;
int lightLevel = 0;
wifiRSSI = WiFi.RSSI();
// ************************* LDR *****************************
long val = 0;
for (int number = 0; number < 10; number++)
lightLevel = adc.readADC_SingleEnded(0);
val = val + lightLevel;
delay(100);
lightLevel = (val / 10) / 100;
hum = dht.readHumidity();
temp = dht.readTemperature();
if (isnan(temp) || isnan(hum))
Serial.println("Failed to read from DHT sensor!");
return;
// builtin analog input esp8266
int sensorValue = analogRead(A0);
float vBat = sensorValue * (3.2 / 1023.0);
if (millis() - lastMillis > 10000)
lastMillis = millis();
Cayenne.virtualWrite(0, hum);
Cayenne.virtualWrite(10, temp);
//Cayenne.virtualWrite(8,Voltage);
Cayenne.virtualWrite(19, lightLevel);
Cayenne.virtualWrite(11, wifiRSSI);
Cayenne.virtualWrite(12, vBat);
Cayenne.virtualWrite(18, 0, "digital_sensor", "d");
yield();
CAYENNE_CONNECTED()
//online = true;
CAYENNE_DISCONNECTED()
//online = false;
digitalWrite(D0, LOW);
CAYENNE_IN(5) // light
if (currentValue == 1)
digitalWrite(D5, HIGH);
else
digitalWrite(D5, LOW);
CAYENNE_IN(6) // pump
digitalWrite(D7, HIGH);
else {
CAYENNE_IN(18)
restartMcu = getValue.asInt();
if (restartMcu == 1)
//Cayenne.virtualWrite(18, 0, "digital_sensor", "d");
//Cayenne.loop();
delay(500);
ESP.restart();
Everything works but RestartMCU works sometimes and sometimes doesn’t work.
What am I doing wrong?
Thank you.
Salutations
