My Graph widget not updating
Hello Everyone,
I’ve created a project with arduino UNO + ethernetshield.
I’ve added a graph widget to make a temperature graph. But its not showing any graph,
Though my device is connected. Here is my code:
From Loop function:
CAYENNE_OUT(VIRTUAL_PIN)
int sensorReading = analogRead(tmpPin);
Serial.print(“From Sensor:”);
Serial.println(sensorReading);
float temperature = sensorReading / 9.31;
Serial.print(“Temperature:”);
Serial.println(temperature);
Cayenne.celsiusWrite(VIRTUAL_PIN, temperature);
Its not entering into CAYENNE_OUT(VIRTUAL_PIN) function.
Pls help me.
Best Regards.
Ban
I did a wrong. My virtual was V1, But it should be V0.
After changing #define VIRTUAL_PIN V0
It is working so far.
Thanks everybody.
Glad you got it figured out! Thanks for updating us :slight_smile:
