My raspberry pi b+ was running a servo motor and stopped - why?
hi - i was running a servo motor from cayenne and raspberry pi but now it wont move the motor at all?
Hello @kab423,
Need more detail to help.
Specifically it would be good to know if Cayenne sees the parent Pi device as Online, and if you can interact with it in any way (i.e. are you still seeing data update in the default Pi widgets like ‘CPU’), or if this is only a problem with the widget you created to control the servo motor.
