My Wifi-Shield wont connenct to the Internet?
Hey I bought the following: Wifi-Shield but it wont connect to the Internet?
Only the WiFi Shield Sketch works to upload the WiFi Shield 101 Sketch is to big to upload and on the Arduino ESP8266 WiFi Sketch it says: exit Status 1 “Serial1” was not declared it this scope
I have the WiFi Shield on top of my Arduino and the Arduion is plugged in with USB…
Of corse i changed the WiFi SSID and Password to my own but it still does not work…
Someone can help me?
(Sry for the English i am German…)
Hi @CommanderKSK,
Can you post the code you’re using?
Also, can you share screenshots or copy/paste the errors you’re seeing?
Thanks.
The complete Error Message is to long and reaches the limit here to post… ^^
@CommanderKSK,
Uno has no Serial1, only Serial.
This is the sketch you need:
Steps:
//#define CAYENNE_PRINT Serial  // Uno only has the one serial port, so... NO DEBUG FOR YOU
char ssid[] = "ssid";
// Set ESP8266 Serial object. Uno only has the one serial port
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
	delay(10);
	// Set ESP8266 baud rate
	EspSerial.begin(115200);
	delay(10);
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
You can use the software serial library if you really really need debug later.
For software serial debug printing, you can add this, and connect the defined pins to an external USB to Serial port adapter.
#include <SoftwareSerial.h>
SoftwareSerial DebugSerial(7, 8); // RX, TX
#define CAYENNE_PRINT DebugSerial  // Comment this out to disable prints and save space
Ok thx @kreggly
The Code works to upload but it still dont connect to the internet and when i choose Tools->Serial Monitor i get something back it is not good but better as bevor ^^
I get “⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮” back from 9600
and “AT” from 115200
i paste in my ssid,password,clientID,clientpw,clientuser so normaly it is right or?
When i plug in the power suply the WiFi LED is flashing for like a third of a second an then the LED is off if this info will help?
Of course you get AT. Serial port is used for ESP communication.
If you still have the PC connected to it, you may be interfering with ESP comms. Might want to try powering the Uno externally without the USB connection.
Already tryed but same result it does not connect to the wifi…
Do you have AT firmware in your ESP?
I dont know what you mean?
I installed all librarys i think
@kreggly ok wait i followed this guide to flash the shield itself to see if it works: Guide
Now the Shield without the Arduino is connected to the WiFi.
But i dont think it works this way with cayenne?..
I also have the same problem using the ESP8266 Nodemcu with arduino Mega. The shield works perfectly because I can load simple codes directly to the shield and from the serial monitor it responds but when I try the above sketch it doesn’t even compile continuous error as below;
C:\Users\HP\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:36:2: error: #error This code is not intended to run on the ESP8266 platform! Please check your Tools->Board setting.
_ #error This code is not intended to run on the ESP8266 platform! Please check your Tools->Board setting._
_ ^_
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Can someone help me with this error?
Eric
I can compile it (to the Arduino) but when the shield is on top of the Arduino you have to select the Arduino as Microcontroller and not the NodeMCU 1.0 (ESP-12E Module) :slight_smile:
It works to compile but the shield don’t connect to the WiFi…
I think something is missing or the shield isn’t “talking” properly with the Arduino…
I have absolutely no clue
#14
Node MCU firmware is not compatible with the ESP Shield Library. If you want to use the shield here, you need to reprogram it with an AT compatible firmware.
You can follow steps 7-13 from this link with your serial dongle. Pay particular attention to step 7. I want to see your best dance moves.
#15
Oh nice thx i will try it out and post here if i was successful :slight_smile:
#16
@kreggly no way out using my adafruit board i now have the following error anyway to solve this?
C:\Users\HP\Documents\Arduino\libraries\ESP8266SerialLibrary\ESP8266.cpp:22:26: fatal error: avr/pgmspace.h: No such file or directory
_ #include <avr/pgmspace.h>_
_ ^_
compilation terminated.
exit status 1
Error compiling for board Adafruit HUZZAH ESP8266.
thanks for any help on this
#17
@njueric,
If you have an Adafruit Huzzah, then this is not the sketch you’re looking for. <>Place Star Wars meme here<>
The library you are referencing in this sketch only applies to AVR boards like the Uno or Mega.
You need this one:
https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP8266/ESP8266.ino
#18
@njueric follow this Adding a New Device using MQTT
#19
…or that :stuck_out_tongue:
#20
WOW @kreggly you are truly the best!!!
I flashed the AT-Firmware with the guide you postet and uploadet the sketch to my Arduino you postet bevor and it works!
My Arduino is connected to the WiFi and i see the temporary widget in the Dashboard.
THX! :smile: :blush:
